Norco Fan controller for Fan Wall
hmchk
Hello everyone,
Just got my Norco system built and powered on. VERY HAPPY! I ran into a problem though... I wasn't anticipating having any issues with the noise of the system as it was going to reside in the basement and in a rack... well... I anticipated wrong. Turns out the fans are so loud we can hear them through the floor and its a little more than me and the roomies are probably going to be ok with. So my question is:
What options are there for integrating a fan speed controller into the fan wall. I'm aware of fan replacements but would rather improve/fix this issue of full speed fans to make it work similar to other servers like our HP DL360G5 which will spin up the fans then spin them down to lower speeds after initial startup. Is this available in the Norco either directly or via a hack? I saw some talk about a 7 Volt Molex...
While investigating options I also noticed that there appears to be some sort of plug on the fan wall. Ref: http://www.wegotserved.com/wp-content/uploads/2009/06/rpc422020.jpg <-- far left pins. What is this? *crossing fingers* is this something that can be plugged into the motherboard to control the fan speed?
I will stop talking now but I think the gist of the question is out there... THanks for any help and creative thinking. With some luck I imagine some others might appreciate any info that might surface.
This might be a cumbersome mod since the fans you have are probably 3pin. And these adapters are stupid expensive, but Directron adjusts shipping costs.
7v adapters - http://www.directron.com/12to7.html
3pin to 4pin - http://www.directron.com/3splitter.html
I came across someone's post on some other forum with a Norco 4220 (I think) who replaced the fans with 140mm fans, and apparently they fit better width-wise than the stock fans.
Dremel + 120mm fans
Also replace the back fans with some 80mm panaflows.
OP, if it's the one unused 3-pin connection in that picture that you are referring to, then no, all that is is an additional fan connection. All the little PCB does is distribute power from the 4-pin molex to the 3-pin fan headers, no speed control or anything else special. I replaced all of my fans with 80mm Panaflo's and I don't have any truoble with temperature. My 1TB WD Black runs about 100F, everything else I have is Green, so I know it's cooler than that.
You could just try running the fans at 7v and see how that works out for you.
The safest way for you to do this for free in my opinion would be to take the end off an old fan or something that had a male and female molex connector meant to daisy chain fans together. The ones that only have the 12v and ground wire rather then all 4.Take the end that would connect to the PSU and remove the ground pin and place it where the 5v pin would go. Then connect it to the PSU and plug the other end in to the board that powers the fans. This will feed 5v to the ground on the fans giving you 7v. No need to spend money on adapters in my opinion if you just want to try them at 7v.
Thanks guys for the ideas. I will definetely try the 7v trick. I'm fully aware of the standard practice of replacing the fans but I would like to avoid this. I would actually almost be more interested in installing a fan speed controller instead.
epimetheus: By any chance if the backplane is just a dumb (no diodes, etc.) distribution panel... what would happen if you unplugged the molex and then plugged a motherboard front fan control into that spare 3 pin? Would the motherboard power the fans? I'm guessing there are current issues that would overload something like this.
I'm looking for something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16835118217 But that would work in an automated fashion. I really am looking for a temperature sensitive fan controller (smaller and cheaper the better).
The 4 fans in parallel would overload a mobo fan header. Those mobo fan headers are generally 500mA max I think. A single stock fan might even be too much, I hear the 4220 comes with screamers. The stock fans that came with my 4020 weren't too bad, they were Sunon's, but they were definitely not quiet.
So been doing alot of looking around and have found a few interesting things:
Molex rheostat: http://www.sidewindercomputers.com/si50warh.html
Internal fan controller (looks promising): http://www.sidewindercomputers.com/aqlt4wdiandc.html
Fancy fan controller thats fun to look at: http://www.performance-pcs.com/cata...e=product_info&cPath=87_137&products_id=23822
But the most interesting piece of info I found was this: http://www.heatsink-guide.com/content.php?content=control.shtml
I think something like the last link might be the perfect cheap little solution. Ideally I would still love a add on system that would introduce fan control as is done in more "complete" server solutions like the HP DL360g5 we have, but I'm not sure how to do that.
Is there anyway/options which allow the motherboard/raid card to control the fan speed?
Also... what might be the best way to monitor hard drive temps?
bump... any one know of any solutions that would give fan control to the motherboard?
