NORCO ds1220
I believe it says on there, PCI and PCI-X which means that if you have a PCI-X slot then you can use it to it's fullest potential while if you don't have PCI-X and only PCI. You can still use it but limited speeds because PCI is not as fast as PCI-X.
However, note that the limit is 120 MB/s. For many things, this isn't an issue.
You can use whatever controller you like, as long as it supports port multipliers. There are two pass-through ports, and two 1->5 multipliers in the 1220.
