Norco 4220 fan bracket - 7Volt possible?
farscapesg1
I've never tried this before, but has anyone tried "undervolting" the Norco 4220 fan bracket to 7 volts to try to reduce the noise from the Delta fans? I tried replacing them with some Arctic Cooling PWM fans like these, but I'm not getting enough cooling in the case (server specs in my sig). My motherboard temps are idling around 40C and my CPU temps are idling around 45C (jumping to almost 60C when under a full load).
Unfortunately, since they redesigned the case, I can't use one of the new 120mm brackets, and I have my doubts that cavediver will be making another batch for the old revision :(
Norco hinted the 120 mm board can be modded for the older case. And undervolting is possible you need to combine wires on the molex to get to 7 volts.
I wouldn't refer to the 7V wiring as 'combining' wires as this might be misunderstood to short wires together!
You are basically running the fan between the +12V (yellow wire) and +5V (red wire) to get to 7V (12-5=7).
Just remember that if you do run a fan in this configuration that you can not use the TACH output in case you want to monitor the fan speed as the output signal is now referred to the +5V power and no longer to Ground!
Safest thing is to by a 3 pin to 3 pin cable that will pull the cable down to 7v. Got some in my case. I believe sharkoon makes them.
Well, I don't use the tach output anyways because I have the fans connected to the fan board and powered by a standard molex connector. According to Delta, the fan's operating range is between 7.0 and 13.8.
I guess my real question was if there would be any problems modding the molex connection to 7 volt when connecting it to the fan board, with the fans connected to the 3-pin connections on the board itself.
You also have to remember that sometimes the 12V output isn't exactly 12V but rather 11.7 or something like that and that may cause issues if the fan does require a minimum of 7V to run properly.
Another thing to consider is that if you run the fans at 7V, the amount of air these fans move will drop considerably (it's not a linear correlation between supply voltage and air flow!). So if you have issues with your internal temperatures right now you aren't helping it with lowering the supply voltage :)
Plus some fans need 12v to get started (referred to as kick start). But modding the connector isn't hard.
OK, thanks. I'll probably try it out this weekend.
I still think that the delta screamers in the case will push more air than the arctic cooling ones I put in when undervolted. Guess I will find out :)
I'm probably going to pick up a Hyper 212+ tonight also to replace the stock cooler on the CPU. I'm hoping that cooler will also work with a Xeon e5640 that I plan on using when I upgrade the server (just have to order a motherboard and memory)...
Well, dropping the stock fans to 7 volts reduced the hard drive temps from 3 to 5 degrees C, with only a slight increase in noise over the fans I tried replacing them. I can definitely feel more air being blown by the fans.
Unfortunately, the CPU and motherboard temps didn't really decrease. Looks like it is more of a static pressure issue... or the two TV tuner cards generating a lot of heat in that part of the case...
