I was wanting to know if anyone has ever successfully hot swapped a drive out of your norco case while the array was up and running? Like if one of your disks went bad and you swapped it out. I've done many tests in different scenarios and can't achieve this. I was wondering if I am simply doing something wrong..
The test system consist of 4 drives on the top row. 2 of the drives are in a raid 0, 1 is by itself ,and the other is for the test pull. If you pull the drive out and then put it back in.. All the arrays disappear and the raid 0 never returns.
I'm using a highpoint 4320 card with a chenbro sas expander(if connected directly it still does it). The powersupply is a 850w Rosewill. I'm currently using the UEK version of the sas expander to do these tests. ANY suggestions are welcome..
