daphatgrant
Fi-yah!
- Jun 15, 2003
pics?
I'm at work right now when I get home tomorrow I'll post some pics of the fan next to the case I guess.
pics?
Quick question: does the Norco have activity and/or failure lights for each drive?
pics?
I think the middle conversion makes sense. As for the rear, I would get some good 80s and call it a day. The good news is that the PSU will also act as another exhaust fan so that will help balance the airflow.
However, I'd personally stick with two 80mm in the back - both your single 120 and dual configurations are a bit clunky. Plus, you might not benefit much since your airflow is still restricted to those two 80mm grilles unless you're willing to do a bit of cutting.
On a side note: since you're trying to reduce the noise levels, I suggest using something other than Sunon fans. Those things aren't designed to be quiet. I recommend using Yate Loon sleeve bearing fans or low speed Panaflos instead.
At least the middle rack comfortably allows for 120mm fans; that's the main airflow going through the drives. the 80mm fans in the rear acts as an exhaust.
I'm wondering how loud a setup with three 120mms and two good 80mms would be...I understand these things aren't made for silence but I'd want it to be as silent as humanly possible if I am to use this rackmount for a future setup.
Recommend any good 80mm and 120mm fans? SPCR would probably be a good start to look at what to get but I'm wondering what [H] feels about them from personal experience.
daph, those fan setups seem pretty ghetto.
Looks good! Now I'm waiting to hear how loud it is with the new fans One question though... why mount the top fans on the outside of the box? Was there not enough clearance to mount them on the inside?
I'm still trying to justify getting this case. Right now my WHS is in an Aerocool Mastige and I could spend $300 on a new case to fit in 3 additional drives I have (500, 400, 300) or I could spend $300 on 3 1TB drives to replace 6 250 GB drives
That is a little weird, you are totally defying the logic of rack mounts, lol.
As far as temps go for before and after I am not sure, never did any testing. As far as noise they are very very quiet, absolute huge difference in noise between the oem and the 120's, went from a 747 jumbo jet to a honda civic noise wise.
