noobish question
sdb_93
what am i getting if i buy a 200$ mother board as opposed to a 50 dollar one?
possibly a better chipset, probably more features & better build quality.
I would say a much better and stable motherboard. The motherboard also determines the overall layout of your computer, providing connections and features you need now and for the future. Also, higher end boards tend to break less and have better customer support.
the higher priced motherboards offer better cooling, many of them have an eight phase power design and importantly are using higher quality japanese capacitors and often using solid ones, the benefit? A long lasting, cooler operating motherboard. Solid capacitors will not leak. These boards usually have a thicker, stronger pcb as well.
dont expect a fifty dollar motherboard to make it past a year and be thankful if it ever does ROFL
not to mention nonexistant updates on cheapo motherboards, poor to no support, poor quality capacitors and ide, pci, pcie channels that go bad etc.
it goes without saying, you get what you pay for.......
that is like asking what is the difference between a Hyundai and a Corvette. Both perform esentially the same task but one does it with more everything. Think about it and do some research.
If you want to do email and internet surfing the $50 mobo will do fine. But if you want to play games at the max and music/video editing you will need more horsepower and a board to support it.
