Wheresatom
- Mar 20, 2007
Ok, so when I first installed WCG I went ahead and just used the WCG version of BOINC. I have a few questions that center around that.
When the work unit I am currently working on is finished I want to uninstall the WCG BOINC, and install the normal one. Once I have installed the new BOINC I want to be able to do work on several projects if possible. How does all of that work? Do I have to adjust settings within BOINC, the project website, or both? Or, does any of that work at all? Would I have to manually stop work WCG to pick up a SPINHENGE and then stop that to pick up a Cosmology work unit?
Hopefully I worded that well. I know I don't want to spread myself too thin, but I also like the ideas of some of those other projects a lot and would like to help some.
