Gettin' ready to install my first wireless devices at home..DLink DGL4500 and VAIO Laptop using 11g.
Been googling security and from what I can tell (beyond a VPN) WPA2 is the way to go...then WPA and WEP...
SSID off and apply MAC filtering...(does this sound bout right for the basics?)
Was just wondering about router CPU overhead and throughput....should I worry about this at all with my new router? Does one encryption add this overhead more than another?
I'll only have 1 VISTA wireless laptop in a wired LAN of 2 XP comps and an HP printer...
Also...my cable modem does VoIP, but the phones plug into the modem which is the gateway, prior to and bypassing my router...thus, I can't really use QoS right with the VoIP traffic right?
Thanks for your replies...
