Noob tubing question
sanitystealer
Hey, I'm putting together a WC setup - and had a quick noob tubing question...
How much tubing should I get?? I've tried using the search function to no avail (it omits the words "how" and "much" from the search..)
I will be using these components:
Thermochill 120.3
Swiftech Apogee
Undecided GPU block
Mcres micro
MCP655
In an antec p180b with an extrnal rear rad mount..
Any ideas? I'm in the dark...
Thanks!
i bought 20. I've found that even as my first time building a WC loop, its pretty hard to screw up. Plus i'll have extra if i want to rearrange everything if i don't like the look once its done.
Masterkleer huh?
How is masterkleer vs tygon r-3603? I was planning on getting about 10ft of 7/16 ID 3603, but am I making a mistake going with that type of tubing? It seems like it might be a tad expensive - is it worth it?
Also, I'm only supposed to have fans on one side of my thermochill right? Or should I 'sandwich' it?
I'm planning on using fluid xp+, for ease of use and lack of conductivity as well, just an fyi :D
Thanks for all the help :)
Masterkleer huh?
There are 2 versions of the Tygon 7/16" tubing... One with a thicker wall (ok) the other with a thinner wall. The 2nd is crap. Avoid it at all costs.
Generally, Tygon 1/2" tubing is crystal clear, stays clear the longest, and is very flexible. It's not, however, worth the 400% increase in price over the Masterkleer. Masterkleer isn't as clear, but it's just as flexible.
Depends if clarity is worth it to you...
On a side note, Fluid XP isn't much better than normal distilled water + 5% pentosin. It slowly gets more conductive as time passes, and there's been some known problems with it... Like dye seperation and other unpleasantries.
I'd just avoid it alltogether.
Masterkleer huh? How is masterkleer vs tygon r-3603? It seems like it might be a tad expensive - is it worth it?
Just get Masterkleer. All clear tubing is eventually going to turn cloudy or develop a film on the inner wall. With Masterkleer, you can just tear your system down and install new tubing, and not worry about the cost. With Tygon you are either go to have to replace it or spend your time ( time = money ) cleaning it.
i used clearflex and tygon , both get cloudy with the time ...with tygon it just takes a little longer .
I can put this in, tygon is very nice to work with, easy for tight turns etc...fluidxp is CRAP...seems to be a 50.50 shot at getting a good batch that doesn't cloud instantly. Distilled water and pentosin are the way to go.
