noob to small form factors
DirtyApe
hi im new to the whole small form factor computer...thing...anyways. im going to build a SSF system for gaming and LAN parties. all ill need is the basics like: fast CPU, reliable mobo(maybe some OC'ing but probably not), geforce 6800 GT to ultra range of graphics card, high end sound card, and a big hard drive. i have the mouse, keyboard, and monitor, all i need is the computer. leaning more towards AMD on this system than Intel because its for gaming. any and all suggestions will be greatly appreciated.
-DirtyApe
EDIT: i forgot to mention that my budget lies around $1500.
I am a big fan of the shuttles as opposed to the mATX cases. The shuttles offer the same performance in a smaller (and imo sexier) package. You cant go wrong with either the sn95g5, sn25p, or even the st20g5 would be a nice choice.
to shadowbreaker:
i dont know much about the quality of Patriot Extreme RAM so im going to stick with kingston, corsair, or crucial on this one. as for the soundcard i will go with an audigy because i have used them for many years and i will continue to use them. im not familiar with motherboards anymore and i want one that is rock solidly stable. i.e. no bugs, quirks, etc...
id also go with at least a 250gb HD because i like to download a lot of anime. thnx again for your thoughts.
I'll personally vouch for Patriot. It's one of the top brands out there and makes some of the fastest you can get. I'm sure others will back me up on this.
can you link some reviews and comparisons? im still skeptical because the RAM is a very very important item with any of my computers.
can someone make some suggestions on which case i should use(preferrably with a handle)? id like to have 2 optical drives if possible and i wont beed more than 1 harddrive. i would like to go with 2gb of RAM but i may only be able to afford 1gb for now.
Patriot is great ram...FYI.
Heres what i would buy....
Falcon Northwest Fragbox 2 - 300$
AMD 3700+ San Diego - 340$
2GB 1GBx2 Geil Value - 170$
MSi Xpress200 mobo - 90$
Ati X800XL - 270$
160GB HD - 90$
DVD+-RW - 50$
OCZ Modstream 420w - 90$
Audigy 2 - 60$
Total: 1460$
He wont OC with the MSi board, so stock cooler is fine, and so is Non-OCing RAM. The X800XL is plenty fast and a 6800GT isnt needed for +2% performance. The Fragbox 2 is pricey, but is an Excellent case, 100 times better than that qpack piece of shit, and has superior airflow.
Better than anything up there...
hello: the sn25P5 should do you well and maybe even save you some money. The P5 has the new VIA audio codec and has been touted as excellent and capable of at least 6.1 sound. I would doubt youll need a sound card at all. The shuttles offer a nice preassembled package, but the downside of the P5 is one spot for anoptical drive,but it has ample room for HDD. It includes a media reader too. The cash you save on the sound card could be put into the video or processor. FX-55 maybe??? That FRAG box is also nice cuz it has a handle, but I really like the shuttle. The power supplies are rock solid and the heat is minimal. They allow some OC if you like as well.[H] has a nice review on the shuttle P5.
Aspire X-Qpack - 100$
AMD 3700+ San Diego - 330$ (ZZF)
1GB 512MBx2 TwinMOS Speed Premium - 100$
Ati X800XL - 270$
Seagate 7200.8 250GB HD - 134$
DVD+-RW - 50$
Enermax Noisetaker 495P - 86$ (mwave)
Audigy 2 Value - 40$
I would go with a blend of what they have both layed out, mostly good choices.
Case is the only case, other than the Monarch Hornet, to have two drive bays. It's also one of the few with a handle.
RAM is RAM is RAM. They all do the same thing, they all have the same reliability/lifetime warranty. A few had some incompatabilities awhile back like GEiL, but I don't know of any that are having any issues right now. TwinMOS will give you tigher timings for gaming. Even with low volts, you should be able to run 2-3-2-5. 2GB is not only totally useless, but something you probably will not be able to fit in most SFF cases or mATX motherboards, unless you get 2 sticks with crap timings.
On the board, the MSI is probably the best for you. No OC options, though. The ECS RS480M has decent OC options, but it's currently out-of-stock. The Gigabyte GA-K8A480M-9 would be the best board for you, 4 memory slots, nice features, good support, possibly OC options and it was supposed to be mid-May, but it still has not shown up. All of those boards would give you a little better performance with an ATi card.
That hard drive has NCQ/good performance - go with whatever though. Not sure what's the best in that size.
Chose that particular power supply because 1. The case dimensions require something short - it's the best I can do 2. It's 2.0 compliant 3. Enermax makes good PSUs.
Audigy 2 Value has the same performance as the Audigy 4. They all use the same features. Slightly better DB on the ZS, though, but way not worth it. Don't go with anything outside of Creative, since you're a gamer. Massive CPU usage otherwise.
just for heads up...i only buy online parts at newegg. i dont really trust any place else with my money so im going to be looking for those parts at the egg. :)
one thing i was curious about...would it be a smart move to go with a PCI-Express mobo with this setup?if so then can you guys point me to some stable PCI-E mobo's? thnx :D
sorry for all of the questions but...by going the AMD athlon 64 3700+ route will i have to use registered RAM or can i use nonregistered/nonECC??
All your mATX mobo questions are solved in the 'unofficial list of good matx board' stickied on this subforum.
and no, you dont need ECC ram
does that motherboard suport he new venice cores ? i heard with out a bios update they wont and that motherbaord doesnt have a bios update for the new cores
will the new shuttle sn25P5 case support either a radeon X800XT or a 6800Ultra? i plan on getting a case that will support these graphics cards because i will not downgrade on graphical performance.
sn25P5 supports a "full sized" vid card. 6800 U is a double wide. Take a look at the review on [H]. That should answer ALL your P5 questions. :D
ok thats awesome. thanks for the info! ill definately be building a SFF now. :D how much do you think i can sell the computer in my sig for? one of my friends wants to buy it and i just offered him $1k for it. so this means i should have the money for a new comp near the end of this month! :eek: :D
1k is a fair price, I would say your rig is worth about $1,200 new. If you're at all interested in oc'ing then don't get the MSI mobo, go with the ECS Xpress200. Newegg had it, but they stopped carrying it last week for some reason. I'm going to get it from Mwave.com, they have pretty good reviews, and since its only $90 I'm going to risk it. Patriot is also the best ram if you plan on going 2 gigs later. If you will be satisfied with 1 gig then get 2x512 twinmos sp. I'm pretty sure that all the micro atx 939 boards are pci-e, It is definentally a good idea to upgrade to pci-e with either a 6800 u or gt or a x800xl. The only micro case with 2 5.25 bays that I know of is the aspire q-pack I would reccomend u get that. It has a handle that supposedly holds up to 40 lbs. I am going to be putting my own handle on it though because i dont trust that plastic crap. The san deigo 3700 will support non-ecc ram.
Well it is the only mAtx with oc ability for now, I emailed Abit and plan on emailing DFI to ask them to make one but for rite now, ECS is the best option, next step down would be the Foxconn, then the MSI. The MSI has ZERO oc ability, the Foxconn has a little.
