I ordered some cable (CAT 6), a crimper, and some ends to play around with. Except, this cable has a plastic piece in the center, and the other cables that I messed around with before didn't (I had successfully made cables before I ordered some bulk). I cut the center plastic piece out, but then I can't arrange the wires to get them into the guide, because the plastic keeps them from moving. I've seen pictures of cable guides on the net where the wires go all the way through the guide, then you cut them to length. Is that what I need since this cable has the plastic in the center?
I feel dumb, this was so easy when I was using wire without the little plastic piece in the middle....
