noob questions
gesicht
seen people talk about the text based agent, were can i download it. i looked around on their site couldn't find anything.
also both of my computers have the same performance score even though one is 1gz amd and other amdxp clocked at 2gz. everything thing under every tab is the same. well they have same amount of ram and same nic.
how do i get it to use more then .89 gb? it says it wants 5 gb to be 100 .
it just seems weird why both pc score everything the same.
gesicht...
Are you using the United Devices client? If so, Let both ofyour boxes roll through at least one complete unit of work... The first time you roll through that setup it doesn't quite recognize what you have running.. After you submit your first results, it will correct itself nicely...
Give it a day or so... Let it get back with the BORG..
Oh also, I don't know of a console/command line versionof the United Devices client. What most people you are watching speak in the forums run, is Folding at Home.
Welcome aboard... ;)
