Noob questions on GPU power consumption...
Camberwell
I plan on upgrading my video card (9600GT) in a month or so and I am looking at the 4870 1Gb, either the Sapphire Toxic, or a reference card with the Accelero Twin Turbo, whichever runs cooler (although I like the fact that the Toxic exhausts out of the back of the case, keeping my mobo etc cooler). I was initially looking at the GTX 260 core 216 as it draws less power, but it's simply too big for my case.
I have seen figures for how many watts the 4870 uses at idle and maxed out, but I will be playing at 1680x1050 and I want to know if this would mean that the card would require less power, or if they only run at idle or full speed?
Also, would my E4600 (@3.12GHz) bottleneck this card at that resolution? I want to hang on until later in the year if possible so that I can afford a Q9450...
Thanks, I did see that thread but it doesn't really tell me if the card will draw less power at 1680x1050 than at say 1900x1200...
No, since the GPU will constantly try to pump out as many FPS as possible. It doesn't matter if there is just one pixel to render or one billion pixels, if something says "render that fast", then the GPU will try as hard as it can to render it as fast as it can. The only reason the GPU won't be at 100% load is if there is poor scaling and you are running SLI/CF, it hits the FPS/vsync cap, or if there is a bottleneck in the system (such as a slow CPU holding it back).
At lower resolutions there is a greater chance that it will be able to hit the FPS cap and thus not work as hard, but generally if you've got FPS to spare you'd rather crank up the AA that extra notch than worry about saving 10w of power.
Thanks guys, that's some great info, especially the thread from Seb1.
Anyone able to tell me if my cpu would bottleneck a 4870?
If it is your system in your sig then I doubt it will bottleneck a 4870. It *might* limit max FPS in a couple of games, but that would be about it. Nothing that you would ever notice in real world game play, anyway.
It is indeed the cpu in my sig - thanks very much, that's just what I wanted to hear! Roll on the price drops next month :D
