Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
ive got a pioneer a-717 amp..its pretty old..like 20 years i think...im not sure how many watts it is..i think 120..anyways..if i got newer speakers with a wattage over the amount the amp has will that be bad?
i have 2 20 YEAR OLD bose speakers...let me tell you somene did well somewhere...the sound is awesome and suprisingly crisp..the most ive ever cranked it to was about 1/3 of the way up...my room is 12x12 about...i kept getting up and opening my door to see if some1 was knocking on it but then i realized it was the bass
heres my setup..(im gettin a cm centurion 5 soon!!!!)
