Noob Question
Mike Hawk
I downloaded speed fan and was just wondering what your computer should run at so that it is not overheating??
:confused:
you will know you have heat problems if your computer starts flashing a blue screen with lots of writing (blue screen of death) and then restarting. shouldnt come to that though unless you manually set your ffan speed too low.
Found out the problem the fan is not spinning to cool the computer
But thanks for the help
