Noob question
mussafry89
I have EK Supreme with acrylic top, and FeserOne UV Green liquid. I just filled up the system, am i supposed to be seeing green liquid through the acrylic casing of the Waterblock?
If so, i am not and i dont know whats wrong :(
nope.
The thing is, the system has been running for a while (2-3 months)... Then suddenly i started getting 100C+ on my CPU. So i thought the pump died, I recently bought a new pump, switched it out, and got some UV Green water instead of clear.
and ive got black tubes so i cant see anything other then in the res.
Hrm...I'm not familiar with the EK supreme. you can ask over at xtremesystems.org or get a new WB like a swiftech GTZ just to be on teh safe side until you find out...
So yeh, i think i just wasted money on a new pump since the pump isnt the problem.
I think the water isnt going from my 120.3 > EK Supreme.
The thing is, i dont get why it would work for 2-3 months then randomly stop.
well if it isn't going into the block, then i suggest taking apart your loop and checking everything to check for clogs/etc
nooooooooooooo i hate doing that... /cry i guess i have to -_- such a nusense. It took me about 4 months just to switch the pump out. I wonder how long taking the loop apart is gonna take.
that's why you go with clear tubing and pure distilled water + iandh silver killcoils or PT nuke ;)
Hmmm... I just drained what i filled and it all came out with these little pieces mixed with the water... anyone know what that is? Like the water is filthy. I think its like something from the radioator... :/ i dont know.
You flush it out beforehand?
Yeh i rinsed it out with hot water, but i guess i didnt do it good enough.
i just had a DISASTER :( I opened the tube that goes rad > CPU thinking it was empty (GAY BLACK TUBES) And all of a sudden a spalsh of clear water comes out and falls on the top of my VGA card :( So i guess my rad was clogging up all the water, and i think i just killed my GTX 280 :(
I took the rad out emptied it out, it was full of green water. I dont know... :S Rad had green water, the tube from rad > CPU had clear water. i dunno :S And when i open up my drain port nothing comes out... how come the water from rad > cpu didnt come out of my drain hole. This is getting confusing and retarded.
long as it wasn't on.
Take the card out, disassmeble it, clean it with isopropyl on anywhere you see the green dye. Then fire it up, if it doesn't. RMA it ;)
The roblem is in my CPU water block :( Blah. Any1 need an extra pump? Im pretty sure they both work fine xD
Another thing, how do up open up an EK-Supreme :S
