Noob question regarding resolutions and performance
Inu
I know im gonna get an LCD and im thinking about getting this AG Neovo AGM CW-19 Black 19" 8ms Widescreen LCD Monitor 300 cd/m2 500:1 0.285mm Pixel Pitch or a different non widescreen monitor. But in either case the resoulution is gonna be 1440x900 for wide or 1280x1024. Im wondering which resolution is gonna be stressfull on a graphics card. I dunno exactly how to figure that since one is a widescreen resolution but if you multiply the two dimensions for each the 1440 reso equals less pixels but not by much. Although i still dunno if thats an offical way to test something like this. Anyone got some insite into this? Any help would be appreciated :)
Performance should be roughly the same in either resolution. There's nothing special about widescreen that makes it perform any differently, unless you use an ultra-high resolution. Stick to 1440x900 as much as possible, since 1280x1024 would always appear either stretched or 4:3 with black bars on the sides.
