(cf)Eclipse said:i've broken those wee chips in ram sticks before and it still works, i wouldn't worry about it... just run memtest on the stick to make sure it's stable
also.. ddr = two bits per clock
sdr = 1 bit per clock
that's... the most important difference imo
pretty much the same thingTopher said:ddr runs at double the rate of sdram
yup, this is true, i was just emphasizingTopher said:pretty much the same thing![]()
lol, waht u ppl do with ur ram? how the hell u brake it, i can understand u can brake off a cpu part, but ram, ugh(cf)Eclipse said:errm, you mean the little resistor/capacitors? i broke 4 of them off completely and it still works
mah teef!Tazman2 said:wtf were u guys using to install them? A hammer?!![]()
Unknown-One said:I know that some motherbaards can take a good beating and still work...
Remember those damn Socket A retaining clips? How many here tried to use s screwdriver to pry it shut?
I sliped pretty good and scraped at least 3 chips off the motherboard (really tiny ones, not sure what they were for) and the compuer still fired up.
But are you saying you scraped a chip off a stick of RAM?![]()
(cf)Eclipse said:mah teef!![]()
good to hear that it's working now. can we have pictures of the damage?![]()
