Noob question about fans/fan controller.
I have a Silverstone TJ09, which comes with 2 x 120mm fans. I decided to buy two more fans to put them on the top. http://www.newegg.com/Product/Product.asp?item=N82E16811999344 The fans that I bought comes with their own fan controllers. However, I want to have the two fans connected to one fan controller instead of two separate ones. Can I just install the two fans and not connect them to the fan controller to let them run on their own? What fan controller would you recommend?
I also have a Big Typhoon cooling my e6600. Also have 2GB of G.skill hz and one 8800gtx. I saw this memory cooler http://www.newegg.com/Product/Product.asp?Item=N82E16835704001. Does anyone know if it will fit?
Your question is a little confusing, but yes, you can run two fans off of one channel on a speed controller, and yes, you can run the two fans together with no controller.
Any fan controller that will let you vary voltage from 0 and up will do fine
And honestly, in my opinion memory coolers are a waste of money.
Thanks for quick response...i'll go with your advice and save some money. thanks again for the help. :)
