Gravestone Doji
- Mar 25, 2006
Hey guys, I've come for a lil help.
I'm putting together a rig and I was waiting for Intel price cuts to take affect. The egg has just now dropped the price on the CPU I wanted. So I pulled the trigger.
Now before Y'all go askin why not a Conroe, I'll be honest and come clean, I'm assembling a Dell XPS 600 that I bought cheap as a barebones package (case, mobo, psu, win XP & driver disk). The NVIDIA nForce4 SLI X16 MCP motherboard is not compatible with the core 2 duo cpu. (I checked and verified this in the dell forums)
Now I know alot of you wouldn't go that route, but I'm kind of excited here. This is my first gaming rig. And hey, after I get done if I'm not happy, well, I can always off it on eBay and chalk it up as experience.
OK, so here's where I need some help. I've put in memory, HDD's, video cards, etc. But I have never assembled a complete system and I have never installed a CPU into a motherboard. So I here's a few questions:
1. I read that Y'all use this thermal compound when putting the heatsink onto the CPU. But which one of THESE should I use?
2. I've looked around but can't seem to find any good documentation on how to install a CPU into a motherboard. This is the most critical and expensive part of the assembly process and I'll admit I'm a lil nervous. Can anyone offer some advice or post a link to some good websites that explain this delicate operation?
3. I'm not too sure about whether or not I should:
a.) first install the bare minimum components to load win xp, and then after everything is running properly, add the other parts such as 2nd HD and DVD burner.
b.) just hook up everything all at the same time and fire it up?
Yeah, I'm a n00b, but i think I can do this. And with a lil advice from some of you seasoned rig builders I'm sure it will go smoothly. Thanks guys
