Steel Chicken
- Jan 29, 2001
OK, just got a dual XEON setup running, with XP Pro installed.
I know XP pro supports duals fine.
My question is, should the logical hyperthreading processors show up in task manager? Ive got them enabled in BIOS, and they show as enabled in the boot screen, but my task manager only shows 2 cpu's....i check TM for settings and didnot see anything to show HT.
Am I missing something simple? I was under the impression as far as XP pro was concenred, the HT does not count towards the 2 cpu limit.
