Thanks in advance for taking the time to read this.
I've decided to purchase system components to put together a nice computer for a small budget... Problem is that I think I may have gotten in over my head.
The first problem I'm encountering is that of the PSU to MoBo connection...the PSU is an Antec, came with the tower I got (a nice Sonata) and has a 24pin connector (even though the manual is calling it a 20 pin..) and the MoBo is a 754, which takes a 20pin connector...I've heard that it's fine to just leave the extra 2x2 space hanging over, and it seems to work that way, but I believe I may be missing out on the power needed on the 12v rail.
When I put some power through the thing, all the drives and fans spin up fine...but there are a few problems I'm seeing after that:
The green power LED on the front panel does not come on...the orange light beneath it will, but the green light will not come up.
The monitor isn't recognizing the system when it powers up (stays without an image, and the orange light also solid there)
When I tried to coax the system into a beep code (by removing RAM and booting up) nothing happened...
K..so I feel like this system I had once fantasized of is now a hunk'a'junk that has been little more than a headache. Any advice, pointers, or input is HIGHLY appreciated.
Thanks again.
Thanks again.
