lethalpimp2998
- Aug 24, 2008
I have purchased and put together a new computer from newegg and i have learned a lot so far, but obviously not enough as i bought a cheap biostar motherboard that sucks. I RMA'ed it and now im trying to find a good mobo for my e8400. I want a motherboard that doesnt need a bios update, just one that you can put the e8400 in and have it working. Also, the RAM here is 1066 mhz and i have a pci 2.0 x 16 videocard.
I was looking at the p5q deluxe:http://www.newegg.com/Product/Product.aspx?Item=N82E16813131297&Tpk=p5q deluxe
Thats the most im willing to spend. Is that motherboard compatible and are there any other you guys can suggest that will work right out of box. No crossfire or SLI needed but if its on the board not a huge deal. Thankyou guys in advance!!! :0
