noob harddrive question
bulldog08
So I'm building my first computer here.. I got an oem WD7500AAKS. I get it and its just a drive. So what else do I need to buy to connect it? Looking at the WD site they have the WDCA030RNN. Is this all I need? Any help on what else I might need? Thanks.
You should have everything you need. The power cables come with the power supply, and the IDE cables (or SATA depending on the drive) come with the motherboard.
edit: Looks like its a SATA drive so that should make it a lot easier also. If you google on how to install a SATA hard drive you should be all set.
great, I don't have my mother board yet. I was just making sure I didn't need to buy anything else. Thanks for the reply!
