I just installed my wc loop and my 2 rad fans plugged into the mobo. I plugged the fans into the motherboard and one is running fast and one slow. How do i get them both at the same speed? Also, should I just plug them into the psu? If i do that, how then do i control them? One fan is basically at full speed and the other one at 1000 rpm.
I have 2 adapters reading "12v -7v" which plugs into the mobo and 2 other adapters tat plug into the psu.
Any help?
Thanks.
EDIT: I guess if i just put one where the psu fan connects to the mobo and another one in the cpu fan place on the mobo, i can control both fans through smartguardian... would that be fine?
Can someone explain what plugging them straight into the mobo would do?
EDIT 2: Wait a minute, it says the PWMIC is at 65c?? I just looked and the psu fan is off. Before i installed my kit it ran by itself when it wasnt plugged in. Now it wont. Oh well, I guess I can use one of the adapters i have that came with the kit to plug the psu fan into the psu lol. Even when i do that its still is at 52c.
Any help?
Thanks.
