Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
will a motherboard refuse to work if no fan is attached? the rpm monitoring used for the bios to be exact. because i'm gunna get an xp-90 and just use large fan with a 4 pin molex
If you boot a first with the old bios-settings, it will probably reboot saying the CPU fan isn't connected.
So enter your bios for you remove the CPU fan, change under "hardwaremonitoring" the fan-control option to "disable".
Most motherboard bios'es will have this option.
I found out the hard way, when I changed to watercooling, and so removed all fan controled by the motherboard.
