Ok, I came into a deal for an SATA WD 120GB HDD. I have the following setup
A7N8X E- Deluxe Rev?
2500+ Barton
Thermaltake Silent Boost cooler
1 x 512MB Crucial PC3200
WD 80GB HDD
Radeon AIW 9800 Pro
My issue is that I want to use the SATA drive as a boot drive but there is nothing in the manual about using a single SATA drive. It only talks about RAID. I have been told by people that this board will support a single SATA drive. I have yet to figure it out. Here is what I've tried so far
I physically removed the 80GB IDE drive then I made sure that the onboard SATA jumper was set correctly. I plugged in the drive and rebooted.I can get the motherboard to recognize the drive, but then it just hangs when it gets past the "press ctrl s to see RAID functions.blah, blah blah. I can't get the PC to boot from floppy or CD so I can't install any third party drivers if I wanted.
HELP!!!!!!!!!
I'd be happy buying a controller card if I have to, but I'd rather not.
If I have to use this as a secondary drive to my IDE drive, I'll be happy to do that as well. I just want to be able to use this drive as I also use my PC as a Tivo.
Again, HELLLLLPPPPP.
Thanks!
2500+ Barton
WD 80GB HDD
Radeon AIW 9800 Pro
HELP!!!!!!!!!
Thanks!
