I've spent a lot of time reading through the forums here (which are a fantastic source of info - thanks!), and I know there are dozens of 'build advice threads' but I haven't found anything that fits my particulars. I don't do much gaming but do intensive photo editing and management (CS2 and PS 5, as well as large databases), some video editing, and a lot of multitasking. Stability is of prime importance to me which is why I'm interested in suggestions regarding non-OC'd (at least for starters
) builds.
I currently have a (very!) old Alienware system running Win2K which I've upgraded in pieces. I have looked into builds from Alienware, Dell, Maingear, CyberPower, DigitalStorm, Puget, Falcon-nw, AVA Direct and even the Gateway FX 7026 from Best Buy (great deal on hardware and nice little system - with instant gratification! - but after opening the case at BB I realized that it is pretty much 'as is,' since it is so small and cramped). I have also priced out components for doing my own build, but found that there are options that are (just about) competitive price wise and don't require the time it would take to get a nice stable system (time is something I don't have much of right now).
Like many others around I narrowed the list down to AVA and Maingear - as well as Alienware (because of discounts as a repeat customer). I can spend $11-1500 for case (meaning not including monitor, keyboards, speakers etc). I started by looking at the 8400's and have moved to the Q6600, and then the Q9300 (for speed, multitasking, possible Vista 64 etc)... Ultimately it seems AVA is the most economical so I've been looking at this Barebones System option:
ROSEWILL, R5605-BK Black Mid-Tower Case, ATX, 500W PSU, Steel
GIGABYTE, GA-P35-DS3L, LGA775, Intel P35, 1333MHz FSB, DDR2-1066 8GB /4, PCIe x16, SATA 3Gb/s /4, HDA, GbLAN, ATX, Retail
INTEL, Core 2 Quad Q9300 Quad-Core 2.50GHz, 1333MHz FSB, 6MB (2 x 3MB) L2 Cache, 45nm, 95W, EM64T EIST VT XD, Retail
ARCTIC COOLING, Freezer 7 Pro Quiet CPU Cooling Fan/Heatsink, Socket 775, Ceramic Bearing, Retail
G.SKILL, 4GB (2 x 2GB) PC2-6400 DDR2 800MHz CL4 (4-4-4-12) SDRAM DIMM, Non-ECC
WESTERN DIGITAL, 500GB WD Caviar® SE16 (WD5000AAKS), SATA II 300MB/s, 7200-RPM, 16MB cache
LITE-ON, LH-20A1L Black/Beige 20x DVD±RW Dual-Layer Burner w/ LightScribe, SATA, Retail
ROSEWILL, RCR-102 Black 52-in-1 Card Reader/Writer Drive, 3.5" Bay, USB 2.0
ANTEC, 120mm Clear Case Fan, Blue LED
MICROSOFT, Windows Vista Home Premium 64-bit Edition w/ SP1, OEM
WARRANTY, Assembled and Tested (1 year parts, lifetime labor warranty, priority service)
$1114.75 before shipping
I had thought I would buy a 9600GT or 8800GTvideo card separately because 1) The cards at AVA seem to be the only component with high mark ups and I could do better from Newegg etc and 2) With the new GPU's hitting the market I figured prices might go down before my build was finished.
On the other hand I could include a PALIT, GeForce® 9600GT Sonic 700MHz, 1GB GDDR3 2000MHz, PCIe x16 SLI, DVI /2, HDMI, from AVA for another $220.64. The advantage would be the total system integration and testing with the final build but I'm unconvinced this is worth it.
Would love to get general comments and suggestions on the build. Also, a few other specific questions:
1) For those who've bought from AVA before, did you buy a Barebones or a Desktop system? Given that, how has the service/product/warranty been?
2) What mobo (chipset and manufacturer) would you recommend? (I definitely need to have dual monitor support so SLI is probably out) Is there potentially a better upgrade path with some mobo's over others (ignore Nehalem for the moment)?
3) Given my use and the price, is it worth moving to the Q9450?
4) Do you think the PSU is sufficient to begin with? Long term I'll probably upgrade it, add another DVD burner, more RAM and HD's etc...
5) As for OS: I've been running 2K which I've been very happy with (and reluctant to part with). Would you recommend a move to XP Pro (32) for stability and legacy support or just biting the bullet and going to Vista (64) Home Premium (or Business?)?
I know that's a lot (especially for a lurking noob
) but I've been very impressed with the advice coming off this forum... Thanks for any help...
