Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
i cut a window in my cdrom, a semi circle over the back of the tray, its a rather tight fit with teh spinning mechanism so i was wondering if i have to put glass in it or if i can just leave it as is
if i where you i wouldn't think about leaving it open. because if i look to myself i am always working with fans etc. when the computer is on. so if you are working on cable management and you would have a cd or a dvd rollin .... think about the los of a finger and a repainted case for free. if you understand what i mean. maby not the best way to say it but i hope you catch my drift.
One alternative to transparancy material would be to use the clear plastic part of a CD jewel case. That would be clear and sturdy, and it should be thin enough to fit in your drive.
