Non Existant Floppy?
jcutner
Another question for you guys.
Got an Asus P5K-SE motherboard, and under My Computer, it shows a 3 1/2 Floppy Drive.
However, I don't have a Floppy Drive. Just one DVD-Burner. Now, I wouldn't think this being a problem, but when I go to turn off windows, it gives me an error about it, and says something similar to make sure the door is shut, can't read A:/
If I cancel it, Windows will still shut down, but very annoying that this keeps happening. Do I have to disable the floppy somewhere in the BIOS?
Thanks.
You probably need to disable the floppy in BIOS, since the floppy is probably "ENABLED" by default.
Thanks.
