So I've got everything hooked up, cpu block, waterblock, two radiators, pump, reservoir, fillport, and t/drain port. But here's the problem. It's noisy!! I spent all this money to get a quieter system, and every so often the pump will make weird/popping noises. I think this is because of micro bubbles or whatnot. I did try tilting my case and stuff and squeezing my tubes, but I dunno it still makes intermittently loud noises. Is there something wrong with my setup? How long do I leave this thing running because I don't think I can sleep with all the noises! Oh and I see a TON of bubbles inside the reservoir.
components:
mcp355 pump
xspc dual bay res for mcp355
2x xspc 360 rads
ek supreme hf cpu waterblock
2x xspc gtx 480 razor waterblock
koolance fillport, koolance drainport
and a bunch of bitspower comp fittings
tube diameter is 7/16 ID and 5/8 OD
UPDATE: Now there's this thick foamy line of bubbles floating at the top of the res, like the bubbles you'd get in the head of a beer. What the heck is going on here?? Is this normal?
components:
mcp355 pump
2x xspc 360 rads
