Drown Babies
- May 29, 2005
I have a hydror 30 pump that makes a noise similar to a loud hard drive accessing. It's not vibrational noise, at least not from the case, since I can pick it up with no difference in sound. I have recently cleaned the inside of the pump to no avail. The sound is almost always present, maybe 80 - 90 % of the time. Has anyone else had a similar problem, or should I try to get a replacement?
