Dark Prodigy
Jawbreaker
- Mar 10, 2006
Okay...
Just finished my brand new W/C setup....
Configuration = Res>Pump>Radiator>Cpu>Gpu1>Gpu2>Nb>Res
Alot to cool I guess... Problem is that I have 1 120mm radiator to cool this thing (and I want to keep it that way for space restrictions)... The Sunon 120 mm High Performance fan that I have to cool my loop sounds like an overhead stove vent... MAD annoying. And of course I have a 120mm case fan (intake).
The Sunon fan is rated at 107 CFM and 3600 RPM and is attached to my radiator in an outtake configuration.
Sys: Amd 4200+ X2, 7800 GT's (SLI), Asus SLI Premium
Temps:
CPU... idles @ 37 C....load @43 (Prime 95 Cpu burn test)
GPU 1 ... idles @ 40 C....load @ 46 C(during 3dmark05 and nVidia Nalu demo)
GPU 2 ....idles @ 41 or so... load @ 47 C ""
NB.... *shrugs*
These temps seem MAD high to me for a WC setup...Tried a Zalman fanmate 2 on the Sunon fan and brought it down to 7V..it got quiet but my temps jumped up at least 5 deg each at idle..
Questions:
#1 ... Would it work to configure my loop cooling with 2 low noise fans in a "push-pull" configuration to eliminate noise and get better temps?
#2 Is it better to expel hot air out of your system or to bring in cool air (If you had only 1 choice)?
Thanks...
Temps:
NB.... *shrugs*
Questions:
Thanks...
