Noctua NH-D15 G2
I have one of these on order for my Intel 13700K I'm hoping for lower temps I already have a High End Noctua 12A but I'm still getting 100 degrees.
Like the Monster Hunter Wilds Benchmark that is with Hyperthreading off even. I should have it installed Tuesday and I'll report back.
No way will I spring for that Thermal Plate heard some people have problems with Ram errors and booting after it's installed.
My one question about the NH-D15g2 is if it is possible to adapt it to AM3. It sounds silly, but I like messing with older hardware, and I would like to use it for overclocking and FX/Phenom II
This cooler is a keeper I enabled Hyperthreading back in the Bios and the cooler does it's job the screenshot is from the Monster Hunter Benchmark and my 13700K.
I was getting 100c on some cores with the Monster Hunter Benchmark on my Noctua NH-U12A "Which I thought it was good for years because hell it's almost the same price" I also ran Intel CPU and didn't get any serious Errors in Thermal Throttling I did get 1 Voltage throttling Message but it took a few seconds for the fans to spin up. My only complaint about the cooler it covers all my Ram RGB it covers it totally with the front fan there is no way around it unless you remove the front fan which would be pretty dumb. If you disable Hyperthreading with this all the temps were in the mid 70s and low 80s.
I have this cooler. It is a beast. Probably going AIO for my next build because 5090 is dumping to much heat into the heatsink and I want to get some fresh air to the CPU, but this a phenomenal air cooler.
It would be cool if they made a version of it for TR4/TR5. Id like somthing bigger than a U14S for my 2990WX.
You pay a premium price for your premium cpu, the fans are what separate them from say thermalright and the vast majority of others, their fans are top notch and should work better and longer than any others.
For someone on a budget or more, thermalright is currently the best in everything, price and overall quality....and they have a bunch of models so you can study endlessly which one would be best for your cpu, mbo and ram.
yeah, with noctua, everyone buying it knows that they are paying a hefty premium. I paid like $80 for a single tower NH-U12s a few years ago, but it has definitely paid off. Specifically, that cooler I can use on any system since Noctua supplies mounting hardware, LGA 775, 1366, AM2-AM3+, it supports it all, and its "free" in the sense that you paid for that convenience up front. This is in addition to the high quality fans and stuff.
I have a nh-u12s, it's a bad cooler considering the huge price, in terms of performance it's no better than the venomous x from 2010.
I'd rather have a thermalright dual tower for half the money.From Noctua, it's only worth having their most expensive and best. (currently nh d15 g2)
Holy these really went up in price Tariffs 179.00 for an air cooler.
They are price gouging. They are $125 ea when you buy a case of them. But depending on the processor its not going to be any better than the older model once you stick a better fan on it.
I went back to my old Noctua Fan NH 12A or whatever when I bought this thing I didn't know about putting SVID behavior on Typical in the Bios.
Sure I get some hotter temps but at least my RGB Ram is visible I plan on upgrading to better Ram. I ran a 4 minute Intel XTU stress test I didn't get any throtting warnings and the highest temp was 83 c I was getting about the same on the Noctua G2 it has better temps but do you really want all that Metal hanging off the MB :p
All that metal hanging off with the right kind of backplate is no big deal at all. I worried about this too until I tried it.
A lot of it is going to be marginal since the surface area increase is not that much and the thermal paste composition is much more critical and there is a lot of junk that they sell in syringes now that remind me of the cheap putty stuff you had to add alcohol to to make it pliable again to spread it. What I find interesting in that department is if you apply the classic white stuff that is used everywhere else correctly their improvements they claim are marginal. But mass of heat sink with the stock metal back-plate is not a big deal. If the heat sink weighed 50Kg then there might be some worry about warping the board.
I have used 1000g coolers, plus the weight of the fans with 0 problems.
Maybe 25 years ago it would have been a problem, things have progressed since then.
306 Gram difference or slightly over a half a pound I'll take it plus I can see my Ram the G2 is just so big.
Or just run a center fan. You only lose a couple of c.
I think T30 140s are available now.. if I was air cooling I would be using them.
If I get a 420 rad then for sure I will get them.
They don't really have any consideration for the board it gets put in.
One thing someone might do is use a copper block or a bunch of shims and raise it 8mm higher or more that way, and of course use something like a threaded end standoff to extend the mounting to the bracket studs.
I'm still getting messages about thermal throttling so I'm going with my G2 again but with Pendragons fan setup recommendation so I can still see the Ram. Hopefully the pulling of air will be good enough. The temps are like 89_90 during stress tests in xtu.
I will say I had a nh-c14s mounted to an Asus Z270 Prime-A for years and I most certainly did have some noticeable warping. Everything worked with it, but it was deformed noticeably.
On a cheap quality board like that, its mostly caused by uneven torque mounting. That would have a tendency to warp overtime anyways. Because they are about half the thickness of a quality board.
Anyone who has an old Venomous X knows how tight it can be, I tightened it as much as I could, it even jumped once, I haven't managed to break a MBO, neither the old P55 nor this AM4 where I now have a Venomous X.
I'm getting comparable temps with the fans of the left side but are pulling air instead of pushing. The middle fan is kinda pushing air to the left tower.
If they get out of control I can just switch them up and bury my RGB ram again. 83 is about tops for Intel XTU
On venomous x the user can add 70 lbs of pressure.
I don't know how it is on the new thermalright coolers. Noctua nh u12s doesn't have that, as many screws go and that's it.
So, if the cooler doesn't fit well, not even 1kg+ of weight will help it. It all depends on the cooler base processing, cpu base, cpu size, etc. As for the mbo, considering that today you can get over 300+usd/eur for the mbo, then even a 5kg cooler shouldn't hurt such a thing.
I don't know what kind of system the Noctua NH D15 G2 has, but it probably has quite low pressure on the CPU (so as not to damage the 400+ EUR CPU) if it's the same system as the NH U12S.
Little late to the party.
Sadly Thermalright has discontinued Venomous X BTK II with adjustable pressure center thumb-screw. BTK mounts were work on all thick base Thermalright coolers.
I think the thumb-screw crossbar from AMD AM4/AM5 Universal BTK could be used to replace non-adjustable crossbar on TRUE Universal BTK, thus making adjustable pressure Intel mount.
Another option (one I've done) is drill and tap hole in middle of crossbar for a pressure screw. Obviously can't be done on thin crossbar, but works well on thick ones. ;)
Thermalright's Venomous X BTK II adjustable pressure mount didn't get a lot of sales. Most people only use a cooler on original build and buy new cooler for new build.
I'm sure if enough people wanted them they would stock them again.
Bit of trivia:
Most of Thermalright's tower coolers use one of their two standard base designs;​
Thick base that first used on Cogage Arrow and a year later on original Silver Arrow, and still used on most of their better coolers.​
This style of base is is easily recognized by it's 'C' shaped top section being about twice as thick as bottom and overlapping 2 sides of bottom part of base.​
Their other fairly common base is not as thick and both top and bottom are about same thickness.​
Easy way to increase mounting pressure is add a shim / spacer between crossbar and cooler base. I've done this using pieces of thin feeler gauge. Just be careful it's not too thick because too much pressure will damage CPU socket.
