I have a Zalman USA LQ-320 LQ320 CPU Liquid Cooler that came with a stock fan and I installed a Cooler Master fan in a push-pull configuration. I took both fans out today and installed two Noctua NF-F12 fans in a push-pull configuration with the Low-Noise Adaptors (L.N.A.). The fans are much quieter now but according to Core Temp the idle and max temps seem to be a bit higher, not by a huge difference but maybe by 3-4 degrees Celsius.
Does that seem about normal? Since the two fans are rotating less they are pushing less air, hence why they are quieter? During Battlefield 4 the max temp is 53. I think before the two Noctua NF-F12s it was 50 or 51.
