Noctua colored corners..
Will be sweet. I don't have any windows on my case so luckily their original scheme isn't bothersome.
Yeah, without a window I would not worry at all but being a big fan of their fans (HAH) I do like to sue them with windows.
haha that pun had to be made I think. I started with just a Noctua HSF and eventually replaced all of my case fans with noctua ones. Now my computer is so quiet I need to replace my PSU fan because of how it sounds.
I went with a large PC and Power Cooling fan.. 1200W and if you don't use over 600W it runs fanless.. My setup is silent.. fans run about 400rpm at idle.. pump runs 50%.. ant farts are louder than my PC.
That is precisely what I'm looking to accomplish! And again thanks to all the accessories you get with your fans I've never been left needing anything. In fact I've used quite a few of them to get the best cable routing.
