- Aug 15, 2005
nopeis it a fake from chy-na?
different batch, slight variance in dye i would assume. i think i kinda remember something like that....nope
That pretty much explains it in a nutshell. Amazing how that seems to happen with a simple change. nothing else was likely changed just from a better dye to a cheaper one.different batch, slight variance in dye i would assume. i think i kinda remember something like that....
edit: there was a switch from taiwan to china and a color change to go with.
https://www.reddit.com/r/buildapc/comments/6o4rzo/visible_manufacturing_differences_between_noctua/
I wonder if this person has ever had multiple of the same fan or not. Fans typically vary in their noise levels. Sometimes a lot. You can get 5 of the same fan. 1 will have a subtle clicking. One will have a high pitch resonance at certain speeds. 2 might be perffect. The last one might have an audible PWM purring sound.different batch, slight variance in dye i would assume. i think i kinda remember something like that....
idk but being moved to china, i would assume so.was there ever any fake noctuas?
but any concrete evidence of fakes/clones coming out?idk but being moved to china, i would assume so.
My Noctua fans are in a solid black box by my feet as nature intended.
