No Video: Shuttle MK40V/VN
Kylixz
I recently purchased parts to build a cheap, yet powerful computer. I'm using a Shuttle MK40V/VN motherboard coupled with an AMD Sempron and Radeon 9600Pro.
I've install all the components... hooked up the front panel connections and set the FSB to 133mhz using jumpers. (Also Tried 100mhz)
I've also tried booting the machine without the videocard, using the integrated video. Still no go, even after resetting the Bios.
I've tried Corsair, Kingston, and Mushkin Ram in the machine, but still no video. Upon powering on, the CD-Rom drive light blinks, as does the Harddrive light... which then remains on. Still no video. I had a similar problem on a Shuttle SFF SN41G2... and the problem was with the ram.
Any ideas on how to solve the no video problem? Is there a conflict between the Sempron and the board?
Thanks,
Steve
Socket A Semprons have a FSB of 166MHz...
So you need to set the bus speed for 166 or 333 whatever option you're given, and you need to use DDR333 RAM (PC2700)...
Also...Whats the true capacity of your power supply? What I mean by that is not whats written on the side like "400W" I mean what are the amperage (A) specs for each voltage on the side of the power supply for:
3.3V = ?A
+5V =?A
+12V =?A
+5VSB =?A
Your AGP card is gonna need some extra amperage to work properly.
MD
Thanks for your help,
+3.3V = 38A
+5V =35A
+12V =21A
+5VSB =2A
I'm using Corsair Value Select PC2700. Two 256mb sticks. Tried them in both slots, and also single.
I set the FSB to 166 using the jumper... but still no video.
Could it be a conflict with the Sempron?
Steve
+3.3V = 38A
+5V =35A
+12V =21A
+5VSB =2A
Steve
Don't believe it would be, do you have the latest bios? some boards actually do need the latest bios to function correctly with the Semprons, I don't know why since they are simply relabelled Athlon XP's..
MD
Well I have no video, so I've been unable to get flash the bios. Maybe if I drop an AthlonXP chip in... it might work?
I'll have to try that I guess.
Steve
