I have a second rig that I'm trying to get back up for folding. It's the folding rig listed in my sig. I got the Vendetta 2 in recently so I bumped the OC up from 2.8Ghz to 3.4Ghz, which I've been stable at before with this motherboard and CPU.
After a few minutes at most of folding with the diskless client, it locks up. I shut the system down, powered it back on and there was no video output. This is with an older FX5200 PCI card. I had a problem a couple times in setting the rig up where I'd get no video, but I was always able to fix it by reseating the card and unplugging/replugging the monitor cable back in. I tried the 5200 in both PCI slots with the same results. The system powers on with all the fans running, but I get no video.
I got a brand new 8800GT in today so I tossed it into a PCI-E slot and I get the exact same thing.
I've tried 3 different sticks of the cheapo HP Micron ram and two different sticks of Buffalo Firestix. I tested the PSU 12v and 5v lines with a multi meter and it's all fine. All necessary power cables are plugged in and I don't see anything on the motherboard that appears to be damaged. I've cleared the CMOS multiple times during all of this, which seems to have no noticeable affect. I'ved plugged both a Dell monitor and my Soyo in to make sure the monitor works and nothing changes.
I'm running out of things to swap out. I'm not tearing my main rig down right now to swap CPUs between the two. I guess if I needed to, I could pull the s775 P4 from my Dell and put it in the folding rig just to rule out the CPU. The Dell mobo doesn't support the E6600 though so I can't do a complete swap.
I don't have any sort of system speaker hooked up to this as it's not in a case. I'm thinking that it might be spitting out an error beep when booting that I'm obviously not able to hear without a speaker. I highly doubt I have a spare speaker laying around here to plug in.
Anybody have any other recommendations besides what I've already tried?
