No video on a upgrade build!
Manimal29
First off, the hardware:
GA-EP35C-DS3R 775 ATX Motherboard
Intel Core 2 Duo E8400 3.0GHz Processor
OCZ Platinum XTC Series 2GB PC-6400 DDR2 Revision 2 ram
Visiontek Radeon HD 3850 256MB GDDR3 PCI-E Video Card
Corsair HX Series 620 Watt ATX 12V Modular Power Supply
The bottom line is I have no video. I am unable to tell you what the bios rev is because I have no video. I bought the motherboard, ram, cpu and video card all brand new. I assembled the machine using proper ESD mats and straps with no issues. I powered the machine up with no monitor attached to simply verify that everything powered up. I received no post beeps of any sort. I then took the machine and attached it to a monitor and got no display. I re-checked all of my connections and tried again with the same result. At this point, I tried a different PCI-E video card. Same result. So far I have tried a EVGA 6600GT, a EVGA 6800GS, and the Visiontek HD3850 I just purchased. No video. I have tried two different monitors. Same result. I get no display at all. The power supply is a Corsair HX620 and the six pin power is connected to the video card. The hard drive is a Western Digital 74 GB Raptor that was in the machine prior to the parts upgrade and has Windows XP Pro/SP2 on it. My intent was to rebuild it with a fresh OS install once I can get video. As a last resort, I removed the ram to see if I could get any beeps from the motherboard. Sure enough on power up without ram, I got the expected beeps from the motherboard. I am at a loss and REALLY need assistance. Any and all help or suggestions are GREATLY appreciated!
Do you have another 775 socket CPU you could try to boot up with?
You could take the motherboard to a computer shop around town and have them check out the mobo with another 775 pro. If it's a newer release of that motherboard, it should have "45nm" on the box. If it does not, that could be your problem. Even if it does, I would still start with having a computer shop check it out and update the bios if necessary. Some shops might do that for free or for a pretty small fee.
UUUUUUUUUUUUUUGGGGGGGGGGGGGHHHHHHHHHHH! I feel ridiculous saying this now after all of the help, but when I originally composed this post, I put down the wrong Model # for my board! The CORRECT Model is the GA-P35-DS3R, NOT the GA-EP35-DS3R. Does anyone have anymore ideas?!
Make sure you have all the proper power connections made to the motherboard. You not only need the main power connector plugged in but the 4pin power connector (near the cpu) as well.
same thing just hapened to me when i swapped in a new dfi lp p35 board. bad motherboard. rma solved problem. unfortunately, a bad cpu will give same symptoms. either you are going to have to borrow a cpu or a mainboard in order to trouble shoot it down to which component it is. seeing that its a gigabyte, i immediately would assume it was the mainboard. but thats just me.
Happened to me last week while installing additional memory for my gf's PC. PC won't boot/post, I had to remove memory to update bios. Works great after.:D
