no USB on Emachines
Status
Not open for further replies.
Pull out the volt meter and see if the ports are actually getting power or not?
Also, did the PSU you replace it with have no negative volt lines whereas the original did?
no negative volt lines? Im not sure. I replaced the OEM with an Enermax Noisetaker.
How would I know if had negative lines or not?
thx
why the heck did I get moved to the power supply section? No wonder Im not getting any response.
Status
