No TPM or TPM has problem
RADEoN
I'm working on a machine that has the error "No TPM or TPM has problem." The cure for this is a BIOS upgrade. I can not install a BIOS upgrade because it will not boot from anything, CD, USB or the Hard Drive. There's no way to flash this BIOS. The machine is a gateway M-Series.
attempt to enter into the bios and then reset the normal bios defaults. Additionally you may want to remove the hard drive to ensure it is not affecting your post processl.
Unplug from the wall (not just flipping the switch), remove the CMOS battery and let it set for a while. I know it sounds weird, but this was the only way I could reset the BIOS on a Tyan board that I had.
This should get you into the BIOS so you can then set "factory defaults".
EH
