Hi, we've been trying to get an ATI x1050 to output to 2 projectors each 50 feet away. The installer had connected it via svid->composite adapter then composite->RG6 coax then RG6->RCA comp at the projector. He then used an RF splitter as a means of splitting the signal off to the 2 projectors. This setup only had a strong enough output to display on one projecter which makes sense due to the long video cable stretches and the added loss in the RF splitter. I then had the installer get a distribution amplifier instead of the rf splitter but he accidentally purchased an RF cable amplifier and hooked this up to the composite from the video card. This obviously did not work at all so he picked up the correct A/V distribution amp. However we still cannot obtain an output to the projectors. We currently have the svid on the card plugged into the svid on the amp then composite outs 1 and 2 are plugged into each projector. We setup many people this way and it always works great, infact this setup works fine with the dvd player svid out but nothing from the card. The desktop extends no problem, it almost seems like the output amplifer in the video card is shot. Could plugging the card into the RF amplifier cause such an issue?
