DaRuSsIaMaN
- Apr 22, 2007
I recently got a refurbished external (USB) wireless adapter by Netgear. It's the WNA3100 but who knows what they did to it while refurbishing it.
I tried using it to connect to the wireless network at my university, and I got the above-displayed error. So what's the deal? This RADIUS thing is not a new technology, right? So any modern wireless adapter should be able to handle it. Why would this thing not support it?
Secondly, if it doesn't work, that's alright. I need a second wireless adapter anyway, so I could use this one at home where the RADIUS thing is not an issue. But how do I make sure this does not happen again with another one that I buy? I can't seem to find anywhere in the specs anything about this compatibility. For instance, I believe I want to get this one next:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166068
(Rosewill RNX-N150HG)
Can I be sure that this one will work properly?
