No sound
master noran
Hi, I just recieved my new asus xonar DX and after installing the card and the floppy connector to the card. I booted up and installed the drivers on the CD, no sound. I even downloaded and installed the newest drivers from the website and still nothing.
Windows is probably still using your old soundcard if its on the motherboard.
Go to control panel and change the default audio device.
I deleted the drivers and everything else for my realtek onboard stuff. I made the new soundcard the defualt device, still nothing....
edit: also I stopped getting a post sound.
2nd edit: ok, so I decided to figure this out later and took out the card, and now I can't get my onbaord sound working. The drivers don't install properly and there is no post sound.
Would appriciate some help, I'm really lost here. I don't care so much for the onboard sound. I want to get the Asus xonar working.
I know this may sound stupid but, try check your master volume settings, is it on low settings or possibly on mute? In device manager under Sound, Video is there any driver conflicts? Try and do this
1. Uninstall the onboard driver in device manager and disable the onboard audio in the BIOS
2. Uninstall the drivers for the Xonar DX sound card and reinstall the drivers again.
