No sound when playing DVDs?
New Start
I tried playing a DVD with WMP 10, but there is no sound. I get sound from everything else.
It's a pre-built Shuttle SFF G4 8500g
Any ideas?
I had same problem. Short answer? Don't use WMP10. It doesn't have the ability to decode AC3 audio natively. You have to download a codec that can use (i.e. AC3filter). However, there is a more elegant and better solution. Media Player Classic is free, small, and includes a DVD decoder (audio and video) and doesn't tax the system as much. There is a world of difference between the two.
That said. Did your DVD player come with any DVD software? Most drives that barebones will come with something. Nero comes with Showtime, I think that Roxio has something, etc. Also, trial versions of WinDVD and PowerDVD are available but I've been told that if you search enough you can find these programs on the cheap.
For all DVD needs start at doom9 and go from there.
