I hope there was not a thread about this same problem, but there is please point me there. Well, my first problem with the ABIT AN7 motherboard was the install of windows XP on raid 0 SATA but some user put me on the right track.
I installed both the bundled drivers and windows XP updates and started checking things and I found out that there was no sound. I check the properties to make sure I was using the right output and I was. I check to make sure my headphones worked and they do. I Checked the latest Nvidia divers and that did help. I check BIOS for settings and things were set right. I really need someones opinion. Is this board dead are can I find a way to make it work?
ABIT AN7
AMD 2800+
1 GIG of OCZ ddr3200
Raid 0 Raptor drives
250 GIG WD drive on promise IDE controller
Plextor 708A burner
Windows XP SP1 with all updates
Thanks
ABIT AN7
AMD 2800+
Plextor 708A burner
Thanks
