no sli in bf2?
dogard
i noticed yesterday after checking my 6800gt temps after a game that my top card was way hotter than the bottom one. i enabled show multi gpu rendering and went back in and it isnt running in sli. my other games are. i am running 7730 drivers. am i missing something obvious, does bf2 use sli.
thanks in advance.
According to the HardOCP benchmarks on SLi and my own SLi experiences with my 6800GT's I'd say BF2 definatley does use SLi. You need to check the games profile and make sure everything's ok with it.
Make sure you are running a current driver. If you are running an older driver it might not have had a BF2 profile set yet.
True, but you can create your own. I believe it uses SFR like most of the games do.
