No responce from rig after installing new hardware.
Jinru
I recently purchased a aftermarket Heatsink and decided to install it last night. I did the usual routine of removing the motherboard carefully and installing the heat sink without a hitch. When I placed everything back in and reconnected what I thought was all the wires I started up the computer and didn't hear a post beep from the Mobo, monitor was still blank, but all the fans were running. So I turn it off and glanced back inside the case and noticed the 12v ATX power connector wasn't plugged in... I had difficulty since the huge Heatsink was blocking my vision but once I had it plugged in, I started the computer up and this time I had no response at all... No fans spinning, no post beep, nothing on screen. All I noticed was a constant thumping noise coming from my speakers when I flip the switch to the back of the PSU on.
Did I blow my PSU or maybe my mobo? I don't have any spare parts to troubleshoot what the exact problem might be. So any ideas before I purchase new parts would be appreciated.
my rig:
Gigabyte 965p DS3
E4300
2x1gb Kingston HyperX
Corsair 520W PSU
radeon x1950xt
Memory or the video card most likely wasn't install correctly. Re-seat both of them and see what happens.
If that doesn't work, set it all up in a barebone bench test config. Refer to the sticky troubleshooting guide, bottom section, for more info.
