No receipt? No Warrenty?
assnips
Hey all
I was looking at a nice monitor on the forums.
But like the title says. He doesnt have the reciept this is from a NEC monitor LCD 1765 to be exact.
If there are dead pixels, bad backlight etc.
Does the warrenty still apply?
Was it registered by the original buyer? If not, then you're out of luck with no receipt.
You're not necessarily screwed:
- First off, the monitor will have a build date, which can be determined by the serial number. If the monitor has a 3-year warranty and the serial number pulls up a build date of July 2002, then it should be covered until July 2005.
- Second, if the original owner bought it online, he may be able to access his account on that site and pull up the order confirmation. Have him print the sucker and include it with the monitor when he ships it.
I had a similar problem getting my rebate from NEC. At first, they did not want to honor the rebate since I didn't have the traditional store receipt that the rebate program required. I sent a copy of the order confirmation and the shipping document that came with the monitor, along with the explanation that this is as good as someone will ever recieve when ordering online, and they accepted that as proof of purchase. Something similar ought to work for wty coverage.
ah. Thats a smart idea. I was trying to find where NEC would honour it without them coming up with an excuse.
Ill see if that'll work.
Thanks
